Activity › Forums › Adobe Illustrator › Measuring the ‘arc length’ between anchor points on a curve
  • Measuring the ‘arc length’ between anchor points on a curve
    Posted by Hannes Nehls on May 19, 2010 at 8:57 am
    I’m wondering whether there is a way to measure the ‘arc length’ (geman: Bogenmass) of a curve in Illustrator in any way. I was doing some intense research on this matter, but couldn’t find any source dealing with this. It might be just be all to obvious – I still can’t find the way.
    I’m doing some sewing patterns and this functionality became all of a sudden highly desirable : )
    Would be wonderful if someone could spread some light on this matter.
    Thanks a lot, Best, Hannes
    Hannes Nehls replied 16 years, 4 months ago 1 Member · 1 Reply
  • Hannes Nehls
    May 19, 2010 at 10:18 am
    Problem solved: Key was to search for ‘path length’. SnapMeasure from nineblock is quite what I wanted! best, Hannes
