Activity › Forums › Adobe After Effects › Measuring Scan Lines
Posted by Dylan Carter on May 26, 2005 at 9:01 pmI get requests when doing commercial work to create logo’s and such that are exactly x amount of SCAN LINES… and way to measure this in AE?
Mark Landman replied 21 years, 3 months ago 4 Members · 5 Replies -
Guy
May 26, 2005 at 9:05 pmyou could get an interlaced frame, where the interlacing is very apparent, and count he scan lines.
Legal text should be 22 to 24 scan lines. -
Mark Landman
May 26, 2005 at 9:23 pmNTSC video has 525 scan lines, 483 of which carry video information. Since most computer systems use either 480 or 486 vertical pixels per image (483 +/- 3), you’d be safe assuming 1 pixel per scan line. Text that is supposed to be 32 ‘scan lines’ tall should be 32 pixels high.
Dylan Carter
May 26, 2005 at 9:34 pm[Mark Landman] “Text that is supposed to be 32 ‘scan lines’ tall should be 32 pixels high”
Cool Thanks. AE have any sort of measuring tool?
W M d
May 26, 2005 at 10:13 pmGrid and rulers may be useful.
View -> Show Rulers
View -> Show Grid
View -> Show GuidesAlso with rulers visible, you can create Guides to use as reference. Click/drag from one of the rulers to set a guide.
Set grid size in Edit -> Preferences -> Grids and guides.
And of course Window -> Info will show the pixel location of your cursor.
Mark Landman
May 27, 2005 at 12:21 amIf your logo is on it’s own layer, just select it in the project window. The size of the layer you just selected is shown at the top of the project window next to the thumbnail image of the layer.
