Activity › Forums › Avid Media Composer › MC8 timeline shows duplicate audio tracks
  • MC8 timeline shows duplicate audio tracks
    Posted by Rebecca Fogel on April 30, 2015 at 10:36 pm
    Hi all –
    I’ve been working in a Media Composer timeline with several audio tracks – a mix of both stereo and mono. Yesterday I added three more stereo audio tracks, but for some reason I see a duplicate of each of those three tracks in my timeline. These duplicates cannot be deleted – for example, deleting one track labeled A17 also deletes the other A17.
    My first thought was to go to the Hamburger menu > Show Track, and then deselect the repeated audio tracks. It worked and I even saved the timeline view setting afterwards. BUT as soon as I used a different view setting (for example, I have one with waveforms and one without) and then switched back to the newly saved setting, the duplicates were back. I have restarted both the software alone and the entire computer, as well as created a new sequence, but I am not having any luck.
    I’m hoping someone can explain why this is happening and suggest a solution, if one exists! I feel like I’m probably missing something very straightforward!
    Many thanks in advance
    -Rebecca
    Specs:
    Media Composer 8.2.0 software only
    MacPro 2 x 2.93 Ghz 6-Core Intel Xeon
    16 GB RAM
    OS X 10.9.5
    Christian Robinson replied 5 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rebecca Fogel
    May 1, 2015 at 12:45 am
    Two screenshots of my issue…
    8787_1.png.zip
    8788_2.png.zip
  • Shane Ross
    May 1, 2015 at 1:56 pm
    I had this exact same issue when I took over a project from another editor. My only solution was to make a new sequence and cut the old into the new.
    It was the dangdest thing.
    Shane
    Little Frog Post
  • Rebecca Fogel
    May 1, 2015 at 5:39 pm
    Thanks Shane. Yeah, I’ve tried to create a new sequence but it didn’t solve the issue unfortunately. Perhaps it’s the project?
  • Shane Ross
    May 1, 2015 at 6:06 pm
    Perhaps. Make a new project, and new sequence, and bring the bin from the old project over…see if that helps. I recall it took me a lot of work to get the sequence right.
    Shane
    Little Frog Post
  • Rebecca Fogel
    May 1, 2015 at 6:14 pm
    Update:
    I created a new project and copied over all the bins from the old one. The duplicated tracks are no longer showing in the timeline, although they do still appear under Fast Menu > Show Track. I can deal with that though!
  • Christian Robinson
    December 2, 2020 at 3:52 am
    I am now having this same issue!
    December 2, 2020 at 3:29 pm
    You may have already figured this out since 2015 (5 years later) but it was the “Fast Menu” reset it to Default. and it will stop duplicating the tracks.
