Activity Forums Avid Media Composer MC7 ProRes file handling
  • MC7 ProRes file handling
    Posted by Dan Merchant on November 6, 2013 at 8:27 pm
    considering MC system in the future.
    I hear MC has difficulty handling Apple ProRes Quicktime files. But this information came from a facility running MC on PC.
    Is there this indeed the case?
    Would MC running on Mac handle ProRes Quicktime better?
    Michael Phillips replied 12 years, 10 months ago 3 Members · 3 Replies
  • Shane Ross
    November 6, 2013 at 8:59 pm
    MC and Quicktime handling isn’t nearly as good as MXF. Avid isn’t designed to work with QT files…it’s getting better, and on a Mac it’s pretty straight forward. But really, I’d convert the files to MXF. Avid MC 6.5 and up now has ProRes MXF capabilities. And since MXF and QT are jsut wrappers, if you “consolidate” to ProRes MXF, it’s basically just copying the media to the Avid File Structure…a process that would take as long as doing it on the finder level. And Avid MC would behave better if you do that.
    But on short form projects, ProRes QT should be fine. ON a Mac.
    Shane
    Little Frog Post
  • Dan Merchant
    November 6, 2013 at 9:21 pm
    thanks again Shane
  • Michael Phillips
    November 6, 2013 at 10:01 pm
    The PC is limited to the inability to transode to, render to, a ProRes codec due to Apple’s position on encoding ProRes on PC.
    Michael
