Activity › Forums › DaVinci Resolve › MC6 AAF -> Resolve 8.1 Lite (no linking to clips on import)
  • MC6 AAF -> Resolve 8.1 Lite (no linking to clips on import)
    Posted by Randy Rubin on January 30, 2012 at 4:11 am
    Looking for some pointers in the right direction. I’m trying to get my feet wet in Resolve and I can’t seem to get an AAF to link to my media. I onlined my sequence to 1:1 MXF and consolidated the media to my local hard drive. I then exported an AAF (with AAF edit prot. selected). When I try to import the AAF into resolve it says unable to link to any clips.
    My original media was 5D Mark II footage that was brought in via AMA, transcoded to DNxHD 36 and then onlined to 1:1.
    Any help much appreciated.
    Thanks.
    Chris Orcfilm replied 12 years, 5 months ago 10 Members · 18 Replies
  • 18 Replies
  • Lauri Laidna
    January 30, 2012 at 9:12 am
    Add the media directory to Resolve’s “Preferences” > “Media Storage Volumes” and then restart the app. Go to BROWSE and add all the media to Media Pool and only then Load the AAF. You can then uncheck the “Automatically import source clips into media pool”. After the AAF is loaded Resolve fins the media from Media Pool.
    This seems to work better.
  • Randy Rubin
    January 30, 2012 at 4:49 pm
    Thanks, I’ll try this out tonight.
  • Randy Rubin
    January 30, 2012 at 9:08 pm
    When I click on my Avid MediaFiles folder in the ‘Browse’ tab, none of my .mxf files show in the Clip Details tab – only folders. Any ideas?
    Randy
  • Joseph Owens
    January 30, 2012 at 9:19 pm
    You should be able to click/open the folders….
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Randy Rubin
    January 30, 2012 at 9:27 pm
    I do and nothing is inside of them inside Resolve.
  • Randy Rubin
    January 30, 2012 at 9:37 pm
    I did open the folders but no media is inside of them in Resolve. They are just empty folders.
    Randy
  • Randy Rubin
    January 30, 2012 at 10:02 pm
    Did a test on my codec. I was using 1:1 DNxHD. I transcoded it to DNxHD 175 and Resolve was able to see the clips. Any ideas why it cannot recognize 1:1 clips and how to fix it?
  • Jef Huey
    January 31, 2012 at 1:37 am
    You may have just made a typo, but there is no such thing as 1:1 DNxHD.
    1:1 is uncompressed. DNxHD is a compressed format.
    That said, we have successfully used 1:1 and 1:1 10bit Avid .mxf footage in the most recent builds of Resolve on Mac hardware. We can not currently CREATE 1:1 10bit .mxf files (really need that). So I am not sure what your issue is.
    What ver Resolve are you running?
    Jef
  • Anish Prithviraj
    January 31, 2012 at 9:11 am
    Jef,
    You should be able to create 1:1 10bit .mxf files using the MXF RGB 1080p and 1080i output type. Similarly, you can create 1:1 8 bit using the UYVY options.
    Anish
  • Randy Rubin
    January 31, 2012 at 4:13 pm
    Hi Jeff,
    I appreciate the help. The issue is that when I create 1:1 MXF files in Avid and try to open them in Resolve Lite 8.1.1, the files do not show up in the clip browser. They are invisible.
    I did a test with DNxHD 175 files and those worked just fine.
    So I’m looking for some help to figure out why they do not show up. They were 5D footage that eventually was onlined to 1:1.
    Randy
