Activity › Forums › Avid Media Composer › MC Adrenaline and AES outs
  • MC Adrenaline and AES outs
    Posted by Daniel Edelman on May 20, 2009 at 9:46 pm
    I’m running Media Composer Adrenaline 2.2.15 and I need to lay off to HDCAM. I have 1 video track and 4 audio tracks. Do I need to tell MC to send audio out through the AES outs, or will it do this automatically? Will It preserve my audio track number when outputting? (i.e. A1 => AES 1 out)
    Daniel Edelman replied 17 years, 4 months ago 3 Members · 3 Replies
  • James Beattie
    May 21, 2009 at 1:21 am
    AES will always be outputting. It’s embedded SDI that you have to set. And you set it under Settings, Audio settings. Output, enable SDI audio.
  • Job Ter burg
    May 21, 2009 at 7:53 am
    As for straight track patching, you will need to go into Audio Project settings -> Output, and select “Direct Out” rather than Mono or Stereo. In mono or stereo out (default), all tracks are panned across output 1&2 (or 3&4). In Direct Out, by default, A1 is patched to output channel 1, A2 to output channel 2, A3 to output channel 3, etc. You can also change that track assignment in the Audio Mixer or in the Audio Project settings.
  • Daniel Edelman
    May 21, 2009 at 3:48 pm
    Cool thanks for the info. I have to get the AES setup because I didn’t realize that the adrenaline’s HD SDI doesn’t do embedded audio.
    Avid MC 2.2.15 Adrenaline, Unity 3.5. HP xw8200: dual 3.4ghz processors, 3gb ram, nVidia Quadro FX 1400, 125gb SATA internal HD, 4gb ATTO card.
