Activity Forums Avid Media Composer MC 8.3 – bin repair issue
  • MC 8.3 – bin repair issue
    Posted by Ricky Barrow on December 23, 2014 at 12:05 pm
    Every time I open my project which started in MC 7.0.3, then was opened with 8.2, I get a message that the bin was created with a modified version of MC – can post exact verbiage if needed. I click repair and it says it has been repaired but when saving project the asterisk never goes away on my bin – like it isn’t saving. Any ideas?
    Ricky
    Ricky Barrow replied 11 years, 9 months ago 2 Members · 4 Replies
  • Michael Phillips
    December 23, 2014 at 1:47 pm
    Perhaps bins were created on a trial version? Try doing a “save as” and renaming bin, or just create a new bin and move the clips over to that and try saving.
    Michael
  • Ricky Barrow
    December 23, 2014 at 2:16 pm
    Thanks Michael – I just purchased Support for 11 dongles, downloaded 8.2 and activated with dongle after updating it. Everything went fine on 8.2
    I posted a question on Avid Community, asking if I was reading correctly that 8.3 is supposed to be installed on top of 8.2 WITHOUT UNINSTALLING first. That may be the issue – guess I could try that as I am still waiting for a response from them since I reinstalled 8.2 and all is fine again.
    Ricky
  • Michael Phillips
    December 23, 2014 at 2:30 pm
    From what I understand, on OS X, there is no longer a need to uninstall first as it is all done as part of the install process. That’s what I did all through beta.
    Michael
  • Ricky Barrow
    December 23, 2014 at 2:58 pm
    Installed 8.3 on top of 8.2 – however the installer removed 8.2 anyway during installation of 8.3
    The problem still existed but I did a Save Bin As (Same Name with “COPY” added to name) and it solved the problem. I could even delete the bin “COPY” and the original bin opens and saves fine.
    I also noticed that it only affects bins opened and/or created with 8.2 — the bins created using 7.0.3 were not affected but I do not remember if they had been opened while on 8.2
    I have a feeling it is a bug, at least with our system Win 7 PC.
    Thanks for the advice in working around this!
    Ricky
