Activity Forums Avid Media Composer MC 5 to MC 4?
  • MC 5 to MC 4?
    Posted by Scott Babcock on September 28, 2010 at 4:16 pm
    Hi, I’m working at a shop that uses MC 4.05. I’m looking to get my own copy of Avid (Mac Pro) in case I need to work at home or take my machine to the office and I’m pretty sure only 5 is available now. Does anyone know if install the new MC 5 and then install MC 4, will MC 4 run.
    -Scott
    -Scott Babcock
    Freelance Editor
    Motion Graphic Designer
    Avid, Final Cut, Premiere CS4/5
    AE, Motion, CS4
    David Jahns replied 15 years, 12 months ago 4 Members · 6 Replies
  • Richard Sanchez
    September 28, 2010 at 4:21 pm
    Two versions on one system is a recipe for trouble (that goes for any program). Especially since both version of Media Composer are qualified for different OSs. I think MC4 is compatible with OSX 10.6.2 and MC 5 is qualified with 10.6.3
    I believe you can bring bins back and forth, as long as you aren’t transferring a bin dependent on a feature of the newer version (like bringing in AMA footage into a Pre MC4 system)
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Scott Babcock
    September 28, 2010 at 5:01 pm
    Sorry, I meant more in terms of only running 4, not both, and licensing.
    -Scott Babcock
    Freelance Editor
    AE, Motion, CS4
  • Richard Sanchez
    September 28, 2010 at 7:06 pm
    You’re talking about buying Media Composer 5, but then installing Media Composer 4. I believe a dongle that is licensed for MC5 will run fine with MC4, but I’m not sure if MC5 comes with a dongle, as I thought they were phasing out the dongles. I used a dongle for my copy of MC5, but that’s because I upgraded since version 3.
    Richard Sanchez
    North Hollywood, CA
  • Scott Babcock
    September 28, 2010 at 7:49 pm
    Great, thanks for the info. Seems like it would work.
    -Scott
    -Scott Babcock
    Freelance Editor
    AE, Motion, CS4
  • Julie Grasso
    September 30, 2010 at 3:22 pm
    I have MC 3 on two separate computers, I use them at different time by moving my dongle to one computer to the other.
    I just purchased MC5 upgrade and want to do the install where I dont need to use a dongle…
    Can someone tell me if installing the upgrade on just one of my systems will deactivate the MC3 on my other system?
    I need to upgrade to MC5 on one to test it out, and keep the MC3 w/ dongle on my other to finish a project I am in the middle of.
    Is this possible?
  • David Jahns
    September 30, 2010 at 6:40 pm
    If you only have one dongle, then your best bet is to upgrade to MC5 and run the 30-day trial.
    Once you upgrade to a full software license, your dongle will be “burned” and will no longer activate your old systems.
    Once you get MC5 installed on all systems, the software license can be moved around pretty easily via de-activate/activate process – as long as you have internet connections on all systems. Of course, only one system can be activated at a time, just like with the dongle.
