Activity › Forums › Blackmagic Design › MB pro – and frozen video on display
  • Andres Posada
    July 16, 2007 at 4:03 pm
    Chris, could you please check if you can input analog video to the Multibridge. Connect any video source through analog cables, either to component, or composite inputs in the MB and check with Deck Control if you have video in please. Thank you.
  • Chris Torella
    July 16, 2007 at 6:00 pm
    Andres Posada
    i figured out the problem – i just need to swithch by FCP video out from NTSC DV to 1080i and that got the down convert setting in the control pannel to work
    thanks for the follow up
    chris
