Activity Forums Apple Final Cut Pro Legacy Maybe a graphics issue
  • Maybe a graphics issue
    Posted by Chris Neto on September 10, 2010 at 6:09 pm
    Hello to you all
    I’m quite new to Final cut pro and i already encounter some issues.
    I think though that the problems i have are related to hardware.
    I’m using a Macbook pro 2.66ghz (mid-2009) with the 2 nvidia graphic cards (9400M & 9600M GT) lately i got the final cut suite 3 and i started to edit a short film i had shot.
    I switched to the 9600M GT for better rendering. But it appears that my mac crashes for some seconds (around 30-40) when i try to edit my sequence.
    The mouse is moving, but i cannot click on anything as is my screen becomes a background.
    I noticed that this was also happening during capture.
    When i tried to capture a HDV tape it had like 3-4 mistakes(scene cut to 2 or 3 parts and some seconds were missing).
    At the beginning i thought it was just because my laptop was overloaded, so i emptied half of my HDD didnt run any applications on the background and of course shut down and restart my laptop.
    The problem didnt go away it keeps on crashing and i have to wait every time for 30-40 seconds until i can go on again.
    I have to add that when i watch a movie with the vlc player, i also get some moments that it freezes for a second and then it goes on leaving behind this “time-loss” pixels. The movie then goes on but it usually happens 4-5 times with a 2hr movie.
    My thoughts went to the graphics card as all these do not happen with the 9400M but only when i switch to the 9600M GT.
    Though when using FCP with the 9400M its substantially slower (rendering, effects, etc)
    Anyone had any similar problems or has any idea what could be causing the issue?
    >P.S i run SL 10.6.4
    Chris Neto replied 15 years, 11 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    September 10, 2010 at 7:25 pm
    Perform a clean install. You didn’t do this when you installed studio right? You’ve upgraded from Leopard to Snow Leopard during the life of the MBP as well without performing a clean install, right? It’s time for a clean installation and things will improve. Clean means backup your data, then erase and install the OS, update it all the way, then install Studio and update it all the way. That’s the only way to keep things humming… Put your docs back and you’re ready to rip.
    I’ve a DVD on setup you might like BTW… it’s in the COW’s Master Training series. It covers this and a lot more.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Paul Dickin
    September 10, 2010 at 7:27 pm
    Hi
    Not an answer, but a comment: my older MBP froze whenever I used Compressor or did a big FCP render until I put it on a flat-bed fan base, which in iStat Pro brought its graphic card/CPU temperatures down dramatically.
  • Chris Neto
    September 11, 2010 at 9:59 am
    I will try that and let you know.
    Thanks in advance.
