Activity › Forums › Adobe After Effects › Maximum RAM for After Effects
  • Maximum RAM for After Effects
    Posted by Cow_fan on July 11, 2006 at 5:26 am
    I’ve read somewhere that the maximum RAM that windows allow an application to use is 2 gigabytes. I’m running after effects with these specs:
    Pentium 4 3.0 gig hyperthreading
    1 gig DDR Ram
    200 gig SATA hard drive
    In one forum, I was told that it was the application, and not windows, that limit the maximum RAM to 2 gig. So how do I increase the limit for After Effects? I think I can do more RAM previews in After Effects and faster work on Premiere Pro if I have about 4 gig of RAM. Thanks.
    Tim Kurkoski replied 20 years, 2 months ago 3 Members · 2 Replies
  • Michael Duff
    July 11, 2006 at 6:15 am
    there is a “hack” that you can do, maybe search the archives or google… But also read this:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=746810&archive=T
  • Tim Kurkoski
    July 11, 2006 at 4:47 pm
    The RAM allocation is a limitation imposed by the OS. The maximum amount of memory that a 32-bit OS (like the non-64-bit version of Windows, or Mac OS X) can address is 4 GB. Since the OS requires a certain amount of that memory and needs to keep some more protected, they limit how much RAM individual applications can use. On Windows it’s 2 GB (as duffbeer911 pointed out, you can increase it to 3), and on OS X it’s around 3 GB.
    More RAM will make your work faster, yes, and also allow multiple applications to run at the same time more efficiently.
