Activity › Forums › Apple Final Cut Pro Legacy › Maximum possible RAM
Posted by Levan Bakhia on June 28, 2006 at 8:46 amI have 16GB of Ram on quad G5, and FCP is using only 2? right? is that maximum? Do I need more? I do uncompressed HD editing.
Levan Bakhia replied 20 years, 3 months ago 5 Members · 5 Replies -
Tom Wolsky
June 28, 2006 at 8:50 amWhat version of FCP?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
Shane Ross
June 28, 2006 at 8:54 am16GB is MORE than enough. A bit overkill really. I edit uncompressed HD and only have 3.5GB Others have 6-8GB. What you can do with what you have is have FCP, Motion, Shake and Safari open all at once…all rendering or doing something.
What you also need are high speed drives. SATA Raid or Fibrechannel.
Shane
Alokut Productions
http://www.lfhd.net -
Walter Biscardi
June 28, 2006 at 11:17 am[Levan Bakhia] “I have 16GB of Ram on quad G5, and FCP is using only 2? right? is that maximum? Do I need more? I do uncompressed HD editing.”
FCP only uses 2-4GB RAM total. I edit uncompressed HD with 3 and 4GB RAM installed in our machines. As Shane says, uncompressed HD comes down to very fast drives.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Mihail Angelov
June 28, 2006 at 1:57 pmHi, check this out https://docs.info.apple.com/article.html?artnum=93844
Levan Bakhia
June 28, 2006 at 4:09 pmWell, it is FCSTUDIO so it is 5.1
I think I only use 2GB of RAM because that is what FCP shows me in system preferences under Memory tab. Also, I understand that I need fast disks and I do have it so actually I don’t have problems with FCP at all, it works fine, but I thought I could get extra benefits after I added 14GB of extra RAM, so I don’t right?
