Activity Forums Adobe Premiere Pro Maximum bit depth-maximum render quality when dynamic linking
  • Maximum bit depth-maximum render quality when dynamic linking
    Posted by Jim Bachalo on June 29, 2012 at 9:07 pm
    Hi
    A bit confused by the use of Maximum bit depth and Maximum render quality as used both in Sequence Settings and also as options when rendering in AME.
    1
    Do you need to explicitly enable these switches in the sequence for best quality or, do you simply need to switch then on in AME when you render in Media Encoder?
    2
    When dynamic linking to After Effects, when should you use an 8 bit vs 16 or 32 bit working space, and, how does this bit depth interact with the maximum bit depth, maximum render quality in PPro?
    Local is the new global
    Jim Bachalo replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
