Activity › Forums › Creative Community Conversations › Mavericks update might cause headaches
  • Mavericks update might cause headaches
    Posted by Andre Van berlo on May 22, 2014 at 7:10 am
    https://www.macissues.com/2014/05/21/10-9-3-causing-headaches-for-mac-pro-users/
    “Some Mac Pro users have noticed that after updating their systems to OS X 10.9.3, their systems are showing significant graphical artifacts that can impact their work in video editing software packages, especially when exporting video files.
    For affected systems, in some cases pink and green lines may be embedded in exported video files, and in other cases the exporting process may stall out and not complete properly. Either way, this issue appears to be a compatibility problem with the drivers for the AMD video chipset in the new Mac Pro, and various popular video editing software packages.
    This issue is being looked into by Apple engineers, so a fix may be supplied soon in a supplemental update to OS X 10.9.3. Meanwhile, there are several things you can do to work around this problem.”
    Scott Witthaus replied 12 years, 4 months ago 6 Members · 10 Replies
  • 10 Replies
  • Nick Toth
    May 22, 2014 at 11:53 am
    Sounds like “click bait” to me. Is anyone here seeing this?
    anickt
  • Oliver Peters
    May 22, 2014 at 12:33 pm
    There’s a thread on this that I started in the Premiere Pro forum. Apparently 10.9.3 causes render issues with Adobe apps and Resolve when GPU accelerated rendering is used. It appears to be tied to the D500 and D700 GPUs on the new Mac Pros.
    https://forums.creativecow.net/thread/3/954153
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Scott Witthaus
    May 22, 2014 at 1:07 pm
    Another lesson in patience before updating….
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
  • Oliver Peters
    May 22, 2014 at 1:40 pm
    [Scott Witthaus] “Another lesson in patience before updating….”
    While true, this affects the new Mac Pros. These are just now shipping, so hard to say which OS comes installed. You might not have a choice.
    – Oliver
    Orlando, FL
  • Nick Toth
    May 22, 2014 at 3:26 pm
    Ah Ha! Thanks Oliver
    anickt
  • Scott Witthaus
    May 22, 2014 at 3:46 pm
    “Some Mac Pro users have noticed that after updating their systems to OS X 10.9.3, their systems are showing significant graphical artifacts that can impact their work in video editing software packages, especially when exporting video files.”
    This is what I was referring to. This line suggest the users DID have a choice!
    Scott Witthaus
    1708 Inc./Editorial
  • Mitch Ives
    May 22, 2014 at 4:38 pm
    [Oliver Peters] “While true, this affects the new Mac Pros. These are just now shipping, so hard to say which OS comes installed. You might not have a choice.”
    I can’t verify this, but someone has also posted on Apple forums that this is affecting his older MacPro (2008). FWIW, I have a 2008 and a new MacPro, but I haven’t seen it in FCP X. Can’t speak to Resolve or Premiere…
    Mitch Ives
    Insight Productions Corp.
    “Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things.” – Winston Churchill
  • Oliver Peters
    May 22, 2014 at 5:14 pm
    [Scott Witthaus] “This is what I was referring to. This line suggest the users DID have a choice!”
    Correct. But, if you buy a new Mac Pro today and get it in 2 weeks, what OS will be installed now that 10.9.3 is out? And will this issue be solved by then? That was my point.
    – Oliver
    Orlando, FL
  • Warren Eig
    May 22, 2014 at 5:28 pm
    Also note, Nvidia released drivers and Cuda for 10.9.3 yesterday.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • Scott Witthaus
    May 23, 2014 at 11:59 am
    [Oliver Peters] “But, if you buy a new Mac Pro today and get it in 2 weeks, what OS will be installed now that 10.9.3 is out? And will this issue be solved by then?”
    That’s a buyer awareness issue. What you do then is not use the new box until the issue is fixed. Tough to do, but solves the problem.
    Scott Witthaus
    1708 Inc./Editorial
