Activity Forums Storage & Archiving mavericks issues
  • Weiyu Chen
    November 12, 2013 at 1:45 am
    Thanks for the detailed info. It helps.
  • Simon Blackledge
    December 9, 2013 at 6:29 pm
    Whats the ACL fix Bob ?
    In testing here 1 iMac (10.9) over 1Gig to a iMac running 10.8.5 with a 6 bay Pegasus stills seeing 105 Write 80/90 Read with other on the networks over AFP.
    SMB2 70 R/W
    SMB 80 R/W
    Anyone running the Solarflare 10Gig nics?
    Cheers
    S
  • George Staffod
    January 16, 2014 at 5:05 pm
    I’m baffled??????
    I’m trying to setup Mavericks Sever (3.0.2) to share files between a group that contains Macs and PCs. The rub is I’m running into what appears to be a very common problem when using SMB. Even tho I’ve created a Group with Read/Write permissions and assigned everyone to that Group the files that are created by one user are not accessible by one of the other users in the Group. I’ve run the terminal command for the ACL fix and it has not resolved this issue.
    I’ve tested this 9 ways to Sunday and nothing seems to work. I see that Bob had this same issue and I was wondering about an update on how this is working for him now and if the terminal fix did in fact resolve this issue for him.
Page 2 of 2
