Activity › Forums › Adobe Premiere Pro › matte lines showing on certain displays
  • matte lines showing on certain displays
    Posted by Erick Steiner on February 11, 2019 at 9:47 pm
    Hey Everyone,
    So I made this video for a client. It was my first whiteboard video.
    https://youtu.be/gS6ogcCY9VI
    It looks fine on most everything I’ve tested it on, except for my cousin’s TV, where it looks like this:
    Does anyone know what I can do to get rid of this using only this video? I don’t have the original files anymore. Because I deleted them in an emergency after receiving final approval. All I have is this H.264 mp4 file.
    Best,
    Erick
    Simon Ubsdell replied 7 years, 7 months ago 3 Members · 6 Replies
  • Simon Ubsdell
    February 12, 2019 at 9:41 am
    Here’s a trick that will work well.
    Make a Color Matte that is the same colour as your darkest area of background. Place it on a layer below your footage. Set the Blend Mode of the footage to Darken. All the nastiness will magically disappear.
    If the result looks to dark to you, apply an Adjustment layer above those two layers, go to the Lumetri panel and adjust the levels to taste.
    (Because your display is badly adjusted, you will also need to add a temporary adjustment layer [before doing the final colour adjustment) and add a Gamma correction to bring the brightness way, way down so you can check that you have fully eradicated the problem.)
    Simon Ubsdell
    hawaiki
  • Jerry Wise
    February 12, 2019 at 6:35 pm
    Drop your movie on the timeline, add Lumetri color. Drop Whites down to minus 20 or so and you will see your masks. Bring up Lumetri Scopes and you will see the difference in white levels on the scope display. Now delete Lumetri Color. Try this: Drop “VIDEO EFFECTS/LEVELS” onto your clip. Bring RGB White Output down to 200. Output your movie. Bring that movie back into the timeline and apply Lumetri and bring down Whites again. See if the hard mask lines are gone.
  • Simon Ubsdell
    February 12, 2019 at 8:01 pm
    There is really no need to export in order to check the result.
    What we do in the VFX world all the time to avoid problems like this (which are very common) is to apply a temporary gamma correction to over-ride any monitor issues, cranking the gamma way up and way down to see if we encounter any problems.
    It’s known as “gamma slamming”.
    Simply delete or disable the gamma correction when satisfied with the result.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Erick Steiner
    February 13, 2019 at 6:28 pm
    Yeah, you’re right. I learned that the hard way.
  • Erick Steiner
    February 13, 2019 at 6:29 pm
    Simon, you’re a genius! Thanks so much for your help. That definitely fixed the problem!
    Cheers,
    Erick
  • Simon Ubsdell
    February 13, 2019 at 8:53 pm
    Glad to hear that helped.
    Obviously there are different ways around this problem such as simply scaling up the white values but I thought this was a fun way to approach it, and it’s a useful trick to know because you are not compromising the original image in any way.
    Simon Ubsdell
    Motion Graphics & VFX Tutorials
    hawaiki
