Activity › Forums › Zaxwerks › material setup problem
  • material setup problem
    Posted by Laurie Pepper on October 18, 2005 at 2:57 am
    Used to be, when I hit “material setup” I got the palette and a map front, back, sides. Now I just get scene preview. No map. No way to put material “one” at one spot, Material “two” at another and so on. Any suggestions? I need my little layout sketch!
    https://straightlife.org
    Laurie Pepper replied 20 years, 11 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    October 26, 2005 at 3:30 am
    Hi Laurie,
    The material set-up window you’re talking about works with native Invigorator objects. If you’ve selected an imported object, then clicked the material set-up window, I don’t believe you’ll see the cross section of the object, because you can’t split materials for imported objects in the same way you can split material assignments for native Invig objects and text.
    Does this help?
    Jon
  • Laurie Pepper
    October 26, 2005 at 4:27 am
    Yeah. I was actually trying to do it with an invig 3d primitive. Which had no sides. Thanks. L.
