Activity › Forums › Maxon Cinema 4D › Material Alpha in Animated texture
  • Material Alpha in Animated texture
    Posted by Eric Lagerlof on August 19, 2007 at 6:32 am
    I’m using an image sequence of .psd (w/Alpha) files as an animated texture. When I used a single image I could see the alpha at work in the preview window(s). But as a sequence, I just see a black square until I render, then the alpha becomes apparent. Is there any way I could maintain the alpha in the working windows without having to resort to rendering?
    I’m using C4D v. 8.2 and the display is set to gourard shading.
    Eric Lagerlof replied 19 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    August 20, 2007 at 1:56 am
    With 9.5(?)+ it’s easy but in 8 there was a plugin and some xpresso solutions but it’s been awhile so unless someone else remembers I would do a search for animated textures in the archives
  • Eric Lagerlof
    August 20, 2007 at 3:54 am
    Thanks Brian. I finally just rendered at key points and massaged it until it worked. And your comment about 9.5 just reminded me again how much I lust after ver.10. Maybe someday…
