Activity › Forums › Adobe After Effects › Matching the look of two lenses
  • Matching the look of two lenses
    Posted by Travis Heberling on February 21, 2011 at 6:14 pm
    We just recently shot a music video using two Canon 7D cameras.
    Both cameras had different lenses and different setting so one camera looks drastically better than the other.
    https://picturepush.com/public/5124314
    This picture is a good example.
    The footage is already color corrected close to the way the video needs to look, and the right side viewer is the better lens of the two.
    So is there a good way to go about getting the lower quality lens to match the higher quality?
    thank you.
    -Travis
    Tudor “ted” jelescu replied 15 years, 7 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    February 21, 2011 at 7:03 pm
    My advice- since you’ll never be able to perfectly match the two sources, the difference being quite “heavy”, make the difference more obvious even by adding grain and heavy color grading to the lesser quality shots.
    Tudor “Ted” Jelescu
    Senior VFX Artist
