Activity Forums Adobe After Effects Matching Layer Window to Comp Window
  • Matching Layer Window to Comp Window
    Posted by Ragno Man on May 10, 2007 at 8:17 pm
    Hello,
    Maybe complex question below:
    I’m doing character animation in AE 5.5.
    Is it possible to work on a character (moving legs, arm, etc.) in a pre-comped layer window which is “synced” to the main comp window containing the background?
    For example, let’s say the character moves left arm at timeframe 5:15 in the layer window. Can the main comp window move to the same timeframe to match?
    Hope this makes sense and thanks in advance…
    Ragno Man replied 19 years, 4 months ago 3 Members · 4 Replies
  • Mike Procunier
    May 10, 2007 at 9:31 pm
    I think I understand. Just undock the Pre-comp window and drag it to a new spot on your screen. I don’t have 5.5 to test it on, but i think you just grab the Pre-Comp’s tab in the viewer window and drag it to a new location.
  • Ragno Man
    May 10, 2007 at 10:34 pm
    I apologize for the long-winded 1st question.
    I guess the better way to put it is:
    How can I get two separate comps linked in time so that when I animate the character body in one comp, the other comp (where the character comp is pre-composed) is also updated in the timeline?
    I hope that this makes more sense
    thanks….
  • Roland R. kahlenberg
    May 10, 2007 at 11:21 pm
    You’ll need to do two things –
    1) Pre comp the body into a ‘final comp’ – seems like you’ve done this
    2) Goto to Preferences and ensure that Under Preview, “maintain time … of related comps” is switched on.
    HTH
    RoRK
    https://www.broadcastGEMs.com
    https://www.myspace.com/rorkrgbspace
  • Ragno Man
    May 11, 2007 at 1:47 am
    Excellent! That did it, thank you!
