Activity Forums Apple Final Cut Pro Legacy Matching grainy footage w HD footage
  • John Fishback
    May 25, 2010 at 7:49 pm
    Nattress’ Big Box of Tricks has some plugins that can be used to degrade the image. Or try adding some blur and desaturating chroma in your HD footage. Is there a way you could “treat” the low rez footage that would work in the edit? Make it b/w, sepia, etc.? That way you can partially maintain the HD.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
