Activity Forums VEGAS Pro Matching Audio To Video Playback Rate Preview.
  • Matching Audio To Video Playback Rate Preview.
    Posted by Dj Smith on April 29, 2006 at 10:00 pm
    hello. i am very new to vegas. so new that im using vegas 4.0 with winxp. i didnt even know there were newer versions. anyway, i have a question. im trying to edit a video. i want to make it slow motion for half the video. im adjusting the ‘playback normal rate’ for the video to .37. i know you can right click on the video stream-then click properties and adjust the playback rate there. the only thing is that it only does it for the video stream. when i use the yellow arrow in the main window to adjust the rate it changes both the audio and video rate automatically. i like the way the audio sounds when it adjusts it automatically like this. i know you can right click on the audio stream-then properties and adjust the pitch/length there, but it doesnt sound the same as the way i want it to when you play it through the main window (yellow arrow). so my question is how do i get the audio stream to match the video when i change the video to .37 playback rate? the way it does automatically when you play it back through the main window with the yellow arrow. i hope this makes sense.
    thanks 🙂
    Edward Troxel replied 20 years, 4 months ago 2 Members · 7 Replies
  • 7 Replies
  • Edward Troxel
    April 30, 2006 at 3:52 am
    [dj smith] “i know you can right click on the video stream-then click properties and adjust the playback rate there. the only thing is that it only does it for the video stream. when i use the yellow arrow in the main window to adjust the rate it changes both the audio and video rate automatically.”
    You can do exactly the same thing with the audio – right-click, properties, and adjust the playback rate. An easier way to do this is to hold down the CTRL key and resize the event. This will adjust the playback rate of both the audio and video.
    Being new to Vegas, you might want to click on the link under my name and go through my newsletters.
    Edward Troxel
    JETDV Scripts
  • Dj Smith
    May 1, 2006 at 9:45 am
    hi jeditdv. thanks for responding so quickly. so i tried out holding down CTRL and resizing the event. that worked, but it only stretches it up to a certain point and doesnt lower/raise the pitch of the audio (which i want). i want to get it slower than that stretch limit. also, i tried using a velocity envelope, which works for the video but it leaves the audio in its original state, so essentially it becomes a slowmotion video with the audio playing normally, hence no syncing. how can i get the audio to match the changes made in the video’s velocity envelope? what i want my video to end up looking like is the way it plays when i simply load it up and adjust tha normal playback rate in the main window to .37 and play it. the video and audio are both slowed waaaay down automatically and in sync and the pitch of the audio is correspondingly lowered-all to the way i specifically want it to end up looking/sounding like. is there a way to save the video/audio in accordance with the the value of the normal playback rate in the main window and the way it plays back?
    thanks so much. 🙂
  • Edward Troxel
    May 1, 2006 at 9:26 pm
    As for going slower, stretch it out as far as it will go, render it, add the new file back to the timeline, and do it again.
    The limits for CTRL-resize are .25x to 4x.
    For the pitch changes, you might right-click the audio, choose Properties, change the “Time Stretch/Pitch Shift Method” to “Classic”, and then adjust those settings as needed (i.e. you might need to check the “Lock to Stretch” box).
    Edward Troxel
    JETDV Scripts
  • Dj Smith
    May 2, 2006 at 9:11 am
    cool. i think i got it now. just a few more questions….
    is there a way to display the amount (between .25x and 4x) that you are resizing as you CTRL-resize events? for example, if i am CTRL-stretching an event i would like to see by how much, numerically (.25x-4x), i am/have stretched the event as it is happening.
    when i use the velocity envelope for the video and add several altering playback rate changes (points), how do i get the audio to match those changes accordingly? i.e get the audio to slow down/speed up in sync with the video as it is playing back.
    thanks. appreciated. 🙂
  • Edward Troxel
    May 2, 2006 at 8:04 pm
    Yes. Look in the View menu for the various options that can be turned on. I believe you want “Active Take Information” after which the % change will appear in the audio track.
    Edward Troxel
    JETDV Scripts
  • Dj Smith
    May 3, 2006 at 2:40 pm
    im using vegas 4 so “active take information” doesnt exist in the view mode. ive looked for something that may be similar to no avail.
    anyway, one last thing.
    thanks!
  • Edward Troxel
    May 3, 2006 at 4:46 pm
    [dj smith] “im using vegas 4 so “active take information” doesnt exist in the view mode.”
    You are correct. In earlier versions of Vegas it was under Options – Preferences.
    [dj smith] “when i use the velocity envelope for the video and add several altering playback rate changes (points), how do i get the audio to match those changes accordingly? i.e get the audio to slow down/speed up in sync with the video as it is playing back.”
    You don’t. There is no velocity envelope for the audio. What you CAN do: split the clips as appropriate and use the CTRL-Resize which will speed up or slow down both the audio and video at the same rate.
    Edward Troxel
    JETDV Scripts
