Activity › Forums › Apple Final Cut Pro › Matching Audio Levels
Posted by Alistair Gallop on October 3, 2012 at 1:30 pmI have an interview with 3 separate people speaking. Is there a simple way to balance with audio so all voices are the same level?
thanks
Ali
John Fishbackreplied 13 years, 11 months ago 3 Members · 4 Replies
Loren Risker
October 3, 2012 at 6:55 pm2 quick options:
Put them in one compound clip and show the audio properties of the compound clip.
Under the Audio Enhancements section click the arrow next to Audio Analysis. Turn on Loudness and play with the sliders until they match.Eye ball the waveforms and drag the audio level bar up until they all more or less match.
OutOfFocus.TV – Original series, music videos, and entertainment for your couch. -
Alistair Gallop
October 3, 2012 at 10:49 pmThanks for that! I didnt explain that they are all on the same channel – part of the same recording, sometimes even the same person speaking but they get quieter / louder – is there anyway to average out the audio so it is a consistent volume?
thanks
Ali
Loren Risker
October 3, 2012 at 10:51 pmYes, both of those methods will work just as well regardless of whether they are different clips or on the same channel.
John Fishback
October 9, 2012 at 10:30 pmYou should set audio keyframes following Loren’s suggestion. You can do this in the Inspector or in the clip itself. Zoom in and put your cursor over the clip. Move it slowly up & down and at some point you’ll see “0 db” pop up. That’s the starting point for every clip and it refers to the level or loudness of the clip. At the same time you see “0 db” you’ll also see a faint horizontal line light up. That’s your level line. When your cursor is over this line and you Option-Click you’ll set a keyframe. Play until the audio is too low or too loud. Back up to just before the level change and set a keyframe. Then play until the audio gets too loud or soft. Set another keyframe and by dragging it up or down you increase or decrease the volume. So go through your clip and adjust your levels using keyframes so they are consistent. Watch your audio meters as you do this. Just be sure you NEVER go above 0 on the meters. Note that “0 db” shown in your clip usually won’t produce 0 in the meters. It doesn’t matter what db is in the clip just what’s in the meter. Most recommendations are to adjust your levels so the meter reads around -12. Once you get keyframing your audio under control you should start investigating how compressors and limiters work. You’ll find them in the Effects Browser under Audio > Levels. Also, there are many free tutorials. Just Google “audio keyframing fcpx” and a bunch will pop up.
John
MacPro 8-core 2.8GHz, 8 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.5Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
