Activity Forums Avid Media Composer Matchframe back to sequence
  • Matchframe back to sequence
    Posted by Darryl David on July 15, 2010 at 2:08 pm
    Hi, here is my workflow. I am cutting with group clips.. Group clips have been dropped into a timeline say A) and then synced with the external bwvs audio files. I then load the this sequence A) into the source. I then cut material into an assemble sequence B) toggle timelines as needed.. My question is, is there a way to matchframe back to this seq A) with the good external audio. I don\\\’t want to matchframe back to the original because it doesn\\\’t have the audio I want. If not this would be a great feature. Matchframe back to timeline that material was cut from. Thanks in advance.
    dedit
    freelance editor
    toronto
    Darryl David replied 16 years, 2 months ago 2 Members · 2 Replies
  • Job Ter burg
    July 15, 2010 at 6:40 pm
    Why not use the BWAV’s when grouping? Or re-group with the BWAVs?
    You can’t matchframe back to sequences, sorry.
  • Darryl David
    July 15, 2010 at 6:52 pm
    Thanks for the reply. The assistants have grouped it this way. Too late. I guess I will just have to use timecode to reference back to seq a). Thanks.
    dedit
    freelance editor
    toronto
