Activity › Forums › Apple Motion › Match motion advice needed
Posted by Steve Norfleet on December 5, 2011 at 11:51 pmHi all
I am doing a comedic sketch where a superhero is holding a giant bag of money over his head. He wasn’t able to keep his hands perfectly still so I need to map the movement of his hands to the giant bag
Any advice on how to do this would be greatly appreciatedSteve Norfleet
Silicon Valley BankDeyson Ortiz replied 14 years, 9 months ago 3 Members · 5 Replies -
Stephen Smith
December 6, 2011 at 12:00 amUse the match move behavior. Apply the behavior to the bag of money and make sure the slip of the superhero is in the source well. Track the hand and you will be good. You should also move the bag of money’s anchor point to where the had touches it.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Deyson Ortiz
December 6, 2011 at 11:22 amHello Steve,
If the match move does not work there is another trick I use in case I have to add keyframes manually, is to add keyframes in halves.
Meaning, if your timeline is 1 minute in length, I would add a keyframe at frame 1, then frame 30 and then frame 60. Take a look, then add keyframes in between those, 15, 45 and then take a look , then keep going in between.
First make sure to add the anchor point where the hands touch the money bag and in between as Stephan mentioned.
It takes some patience.
If you post the video we may be more of assistance.
Have a wonderful day! 🙂
– Deyson Ortiz – Editor / Motion Graphics
_______________________________________– View my work at: https://deysonortiz.com
– Download Free Motion Master Templates at: https://motion-master-templates.com/
– Watch my Apple Motion Podcasts at: https://my.creativecow.net/Deyson-Ortiz/podcasts
Steve Norfleet
December 7, 2011 at 6:16 amThanks to you both. Achieved great results using both ideas!
Steve Norfleet
Silicon Valley Bank -
Stephen Smith
December 7, 2011 at 3:24 pmHappy to help. Best of luck.
Stephen Smith
Deyson Ortiz
December 22, 2011 at 12:42 pmGlad everything worked out. 🙂
