Activity Forums Panasonic Cameras Match HPX500 and HPX250 when recording 576i
  • Match HPX500 and HPX250 when recording 576i
    Posted by Niklas Wikman on April 18, 2012 at 6:28 pm
    Tomorrow, I’ll be using our own HPX500 (set to record 576i, 25fps, 16:9) together with a rental HPX250 I’ve managed to set the aspect ratio alright, but when it comes to format, I can only set 576-50i.
    Codec on both cameras are DVCPro50.
    I did a quick test, importing both footage from our HPX500 and the HPX250. And the footage from the HPX250 looks somewhat different on computer screen. Not as it’s progresive, but still – the movements looks “jaggier”. (to be fair the test shoot was handheld on the 250, the HPX500 footage was on tripod).
    I don’t have the HPX500 at hand, but a look in the manual says that it does record in 576-50i as well. (I was worried that the HPX500 cannot record at 576-50i, but rather 576-25i).
    The shutter on the HPX250 is set to off.
    What else can I check on the HPX250?
    I just came to think of the settings for Film Cam or Video Cam on the HPX500 (under Scene file – Operation type) but there are no such option on the HPX250.
    Surely, I will try to match all the scene file settings as much as possible (Gamma setting, master pedestal, etc). But I still wonder why the movements in the footage looks different…
    Any help is greatly appreciated!
    Chris Tompkins replied 14 years, 4 months ago 2 Members · 1 Reply
  • Chris Tompkins
    April 18, 2012 at 7:56 pm
    According to the manual the 250 will record 25 in 576/50i mode.
    You select 576/50i as the recording mode and then the frame rate.
    See Pic:
    Chris Tompkins
    Video Atlanta LLC
