Activity Forums Apple Final Cut Pro match frame: play beyond out point
  • match frame: play beyond out point
    Posted by Georg P. mueller on September 20, 2013 at 8:22 am
    Sorry if this is a stupid question but I need help to figure this out: Whenever I match-frame a clip from the timeline and play it in the browser it stops at the out point. Pressing play will do nothing. If I want to play beyond that yellow border I need to either delete the selection with option+x or fiddle with the mouse to click outside of the border in order to continue playing it. Drives me nuts…!
    Is there a way to force FCX to just continue playing over that out point?
    Georg P. mueller replied 12 years, 11 months ago 3 Members · 4 Replies
  • Ronny Courtens
    September 20, 2013 at 9:51 am
    Instead of pressing the Space Bar press SHIFT+CTRL+O (“Play To End”) to play the selection beyond the out point.
    – Ronny
  • Georg P. mueller
    September 20, 2013 at 10:22 am
    Thanks Ronny, for your quick answer. This is great, but it still does not quiet behave like I would like it to. I can now continue playing (yeah!) but as soon as I hit the spacebar I find the curser locked back into that yellow box again…
    I also tried to hit “I” to set a new in point on the fly while it is “playing to end” but it does not set it. Instead this deletes the old selection. If I now hit the spacebar again it will start playing where the just deleted selection started… And only then I can set a new in and out. I think there may be a better way…
  • Andy Neil
    September 20, 2013 at 4:46 pm
    First of all Georg, I firmly believe this is a bug. Something that cropped up in the last couple revisions. I don’t remember it stopping playback at the end of the selection in earlier versions. So, do what I’ve done and file a feedback report to Apple in the Final Cut Pro menu. Hopefully they’ll fix the behavior because it’s not one that makes a whole lot of sense.
    However, there is a workaround. When you matchframe to the event browser, hit the slash key (/) to play the selection. When it reaches the end, you can then hit spacebar to continue playing the clip past the outpoint without destroying the IN/OUT in the event browser.
    There are a couple of other ways to bypass this annoying behavior which to me clearly signifies it as a bug rather than a feature. But seriously, send feedback to make sure they know it’s not a useful behavior.
    Andy
    https://www.timesavertutorials.com
  • Georg P. mueller
    September 21, 2013 at 6:42 am
    Thanks Andy. Cool! That does indeed work! But I need to play the entire selection before moving on.. I take it that this is the best known workaround (clicking is definitely worse). In the meantime I have followed your suggestion and submitted a bug report.
