Activity Forums Apple Final Cut Pro Legacy Match Frame doesn’t show all audio in Source
  • Match Frame doesn’t show all audio in Source
    Posted by William Holden on May 2, 2011 at 11:14 pm
    Hey,
    So I just got a cut from my editor and I am laying in all of the additional audio tracks (Cut with mix and boom, I’m laying in lavs and plants). But when I match frame off of the sequence, the clip comes up in the viewer with ONLY the mix and boom.
    I went back to the stringout/dailies project to make sure the editor was working with all of the synced recorded audio and he is. As a workaround, I have both projects open and I’m opening each clip cut by cut. But this is taking me much longer than using match frame.
    Is this just a setting thing? Has anyone had this issue before? Why aren’t all the audio channels appearing in the source when I am positive that there were 7 tracks synced to that clip?
    Will
    William Holden replied 15 years, 4 months ago 1 Member · 1 Reply
  • William Holden
    May 2, 2011 at 11:41 pm
    I also just started playing with the Match Frame > Source File tool (option+cmd+F) but it still only opens the source polywav instead of the synced up master clip I’m using in the dailies project…
