Activity › Forums › Panasonic Cameras › Match ? Film with hvx200
  • Match ? Film with hvx200
    Posted by Rumpot on March 31, 2007 at 3:43 am
    Could I get this stuff to match?
    We have currently ~2h30m that was telecined( from a russian 35mm camera) to digibeta & working in FCP @ SD uncompressed(4:2:2). Could we mix footage from the hvx200 shot in a film mode to match for pick up shots and new scenes, or would there be allot of correction involved?
    Prolly won’t go back to film( since the telecine was to SD, and we only have 1 digibeta master of the 3) so final output will be 480p from the SD uncompressed masters.
    Regards
    _Eric
    Noah Kadner replied 19 years, 6 months ago 2 Members · 3 Replies
  • Noah Kadner
    March 31, 2007 at 3:46 am
    If it’s going to stay in 480 I don’t see why not. ‘Matching’ is more an issue of lighting, composition, etc at that resolution.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Rumpot
    March 31, 2007 at 4:11 am
    The green screen stuff will be the same lights and such, but its just the outdoor footage I’m worried about. It suxs to get to telecine only to realize your lenz had a a UV leak, film after you buy, clean , develop then telecine is adding up quick$$$$ specially when you can’t tell in the field. Lots of shots to redu, and hoping I can match this..
    _Eric
  • Noah Kadner
    April 1, 2007 at 8:01 pm
    Welcome to the realities of film/hd-making 🙂
    -Noah
