Activity Forums Adobe Premiere Pro Mastering a Children’s Music Video in Premiere & Encore CS6 Questions
  • Mastering a Children’s Music Video in Premiere & Encore CS6 Questions
    Posted by Jane Kirk on May 29, 2013 at 7:50 pm
    I am currently making a children’s music video, mastering both DVD and Bluray Disc.
    I have seven Premiere projects, each with one music video. I am wondering the best way to import or link them into Encore.
    The menu will be simple. Three buttons Play All, Chapters, Special Features. Chapters and Special Features will each have a sub menu with individual videos.
    1. Should I dynamic link every sequence into Encore and then create the playlist? Or Should I render all the files into MPEG2 for DVD and place them on one sequence in Premiere first?
    2. What is the best HD format to render my sequences for a Bluray Disc?
    3. Some of the music videos were filmed and edited in 24fps and some in 30fps. Will this be a problem in Encore?
    Jeff Meyer replied 12 years, 11 months ago 3 Members · 2 Replies
  • Jeff Pulera
    May 29, 2013 at 8:40 pm
    For future reference, you can create multiple sequences in ONE Premiere project, so you could’ve done all 7 videos in the same project. Maybe you already know that and have your reasons, just sharing in case.
    I would render out the “MPEG-2 for DVD” clips and then Import them into Encore. Less headaches! Add up the total run length of all clips, so that you encode to MPEG-2 at a bitrate that will fit on the DVD. Use an online bitrate calculator, or use 560/minutes=bitrate (round down a bit for safety margin/menu overhead), and don’t exceed 7 or 8 max.
    For Blu-ray, encode as “H.264 for Blu-ray” using one of the presets in AME. Can’t answer your question of mixed frame rates, sorry.
    Jeff Pulera
    Safe Harbor Computers
  • Jeff Meyer
    May 30, 2013 at 7:16 am
    1) I would pick File -> Export -> Media in PR, pick BluRay, Best quality (your frame size/rate) then press Queue
    After you press Queue, Media Encoder will open. Pick the line with BluRay/Output setting and press CMD/CTRL+D to duplicate the output. Change the duplicate output to a DVD output. Now when you press PLAY you can have Media Encoder create DVD and BluRay files in a single step. Just bring those files into Encore.
    Tip: Export them to separate folders. I think each output will create 4 files, 1 video, 1 audio, and 2 metadata. It’ll be easiest to bring files into Encore if all the DVD files are in one folder and BluRay in another.
    2) If you Dynamic Link into Media Encoder you don’t need to worry about this. If a web/mobile output will also be a thing add an H.264 output in Media Encoder.
    3) I’m quite certain the BluRay player and TV will make a handshake at a given frame size/resolution when you start playing a clip. If you go to a clip with a different size or rate it will break that connection and establish a new one at the required rate. It’s like when the extra features on a BluRay are in SD. Build a test disc, and if it proves a problem in more than one player just export your 24p at 29.97. Media Encoder is smart enough to add a proper pull down along the way.
