Activity Forums VEGAS Pro Master Volume settings
  • Master Volume settings
    Posted by Gerald Stokes on June 22, 2008 at 2:59 am
    Hello,
    This sounds like an easy one, but here I ask. I want to set all the audio in my project to one setting. I really want all the volume to peak as high as it can without going in the red. All the audio in the project has different levels, so I need to be able to apply one level project-wide. I have tried the master volume FX and select volume, problem is, once the audio timeline hits a new piece of audio it goes in the red. Anyone?
    Bruno Simon replied 17 years, 11 months ago 3 Members · 2 Replies
  • Terry Esslinger
    June 22, 2008 at 4:27 pm
    One possible way. Set your Normalize level in preferences. Then individually normalize each audio clip. Could be a PIA if you have a lot of clips. But each clip should then have their highest level adjusted to the level you set in preferences. You might need to play with Compressor before the Normalize depending on the individual clip.
    Terry Esslinger
  • Bruno Simon
    September 19, 2008 at 10:42 am
    use WAVES L2 plugin on the audio master fx. set it to -0,2db. it will limit the entire project sound before reaching the peaks.
