Activity › Forums › Media 100 › Master to Tape/Time Code Part 2
  • Master to Tape/Time Code Part 2
    Posted by Jack Shepard on October 16, 2007 at 2:11 pm
    Mastering to tape now works fine (almost) – thanks.
    One problem seems to puzzle me. There seems to be a delay to when
    the assemble edit/insert edit begins recording – and it is always consistent
    1 second and 9 frames. So if I set the program in point at 1:00:00:00 – it
    won’t actually record until 1:00:01:09.
    Can’t figure this one out. At first, I thought it might be a drop frame/non drop
    frame issue as I am working with both kinds of programs at the moment. But
    they seem to be consistently 1 second and 9 frames off regardless.
    Any ideas? The easy work around is to start the program at :00:59:58:21 but I would
    like to get to the crux of the problem? Could it be a deck setting? A genlock setting?
    It is not the leader as I have tried it with it both on and off.
    Jack
    Jack Shepard replied 18 years, 11 months ago 2 Members · 2 Replies
  • Abercrombie Pupputnick
    October 16, 2007 at 3:40 pm
    What release and CPU do you have? That sounds like a problem reported against 11.6 on MacPro systems. I think it’s fixed in 11.6.4.
  • Jack Shepard
    October 16, 2007 at 6:58 pm
    MacPro
    2×3 Ghz
    8-core
    4 gigs Ram
    version 10.4.9
    Using Media 100HDe 11.6.2
    I’ll go ahead and update to 11.6.4 – actually might as well go up to 12.
    Thanks, hopefully that will do it.
