Activity Forums Apple Final Cut Pro Legacy Master to tape from FCP – Any advice please
  • Master to tape from FCP – Any advice please
    Posted by John White on May 13, 2010 at 12:57 pm
    Hello everyone. Any help would be much appreciated – this thing is driving me nuts.
    I shoot Sony EX1 and I’m trying to master from MBP onto HDV or DVcam via firewire onto a Sony HVR M15 deck, but it won’t happen, I’ve tried it all. Can someone PLEASE guide me as to …
    Import settings
    Seq settings
    Seq render codec
    Edit to tape, or print to tape
    Firewire settings
    View settings
    A/V devices settings
    A/V settings & Device control settings
    This is for two reasons : I need to master my finished programme to tape, and (old fashioned I know) though I do leave the material on the drive, I quite like to back up all my footage to tape also (I guess I just don’t trust HDD tec too much)
    I normally shoot from EX1 onto the SXS cards at PAL SQ 1080 50i.
    Then after importing from the cards into the MBP, I’ll back them up to DV tape going from the camera via firewire into the deck – all works fine.
    I’ll then do the edit and ftp it to the client (or DVD)
    Recently I’ve started shooting at HQ 1080 25P – which at 35mg, I can’t commit to tape at all from the camera, meaning I’ve no media back up of the tapes I then need to erase.
    Sorry to go on but I’m going in circles
    Thanks in advance
    John
    Chris Tompkins replied 16 years, 3 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    May 13, 2010 at 5:45 pm
    You need this plugin for starters: https://pro.sony.com/bbsc/ssr/micro-xdcamexsite/resource.downloads.bbsccms-assets-micro-xdcamex-downloads-LogTransferUtilityAppleFCP.shtml
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • John White
    May 13, 2010 at 5:58 pm
    Thanks Jerry – that’s a new one …
    Is that what I really need ? I already have Log and transfer, and all the SXS browsers etc, and I don’t have a problem importing the footage – it’s at the other end, after the edit where I come unstuck
    John
  • Chris Tompkins
    May 13, 2010 at 6:54 pm
    HQ 1080 25P Well you can’t lay that out to DVCAM SD
    Some HDV decks you cannot master to.
    Are you going Firewire from the mac to the HDV deck?
    Are you using Edit to tape? Then dragging your sequence onto the edit to tape window – assemble edit? Setting in point TC?
    Chris Tompkins
    Video Atlanta
  • John White
    May 13, 2010 at 7:16 pm
    But I can go 1080 25P to HDV can’t I ?
    Yes I am going firewire from the mbp to the deck – I can use the deck to master because previously I’d dump all my SQ 50i footage via firewire from the camera, though I think that was to DVcam.
    Is Edit to tape my easiest option ? (what’s the difference with Print to video ?) I have had a degree of success with Print to video, but the output monitor displayed a horribly squashed and distorted image
    With Edit to tape, to be honest I’m uncertain of the myriad of settings (see my first post) that need to be correct, but I’ve gone firewire into the deck, and video out into the monitor where I can see the decks on screen display , but no pic.
    I know I’m not far away from sorting this – it’s bound to be one stupid thing (probably me…)
    Thanks Chris
  • Chris Tompkins
    May 13, 2010 at 10:45 pm
    Print to video will work too.
    Chris Tompkins
    Video Atlanta
