Activity Forums Apple Final Cut Pro Legacy Master templates are white?????
  • Master templates are white?????
    Posted by Sachin Desai on December 5, 2009 at 3:56 am
    Hello all.
    I upgraded my FCS 2 to FCS 3. everything was running OK it seemed until i created a custom template from motion 4 and called it in my new FCP 7. it all came white no video or text or anything??
    So i tried updating other softwares like OS, Quicktime and all but the result is the same…
    I’ve mac pro 8core, black magic multibridge extreme. i tried without my multibridge also just to check if it works with native dv project. but it was unsuccessful..
    I tried apple forums but didn’t find proper solution
    what should be the problem..
    Sachin Desai replied 16 years, 9 months ago 2 Members · 2 Replies
  • Neal Broffman
    December 5, 2009 at 4:18 am
    I had a similar problem and, after searching on the Cow, solved it. Try this; update your Magic Bullet Colorista plug-in. Do you have it? If not then you have another issue going on.
    Neal Broffman
    One Production Place, Atlanta, GA
    “Voices of Freedom”, Special Jury winner for Fall 2008 CINE Awards produced for the High Museum of Art in Atlanta as part of a major exhibition of vintage Civil Rights Movement photographs, “Road To Freedom”. Currently on display at The Field Musuem in Chicago followed by The Skirball Cultural Center in LA in the fall and The Bronx Museum, spring 2010.
  • Sachin Desai
    December 14, 2009 at 10:16 am
    i have it let me try updteing it…
    thanks
    i’ll try
