Activity Forums Apple Final Cut Pro Legacy Master Template problem
  • Master Template problem
    Posted by Atticus Brady on July 17, 2009 at 3:50 pm
    Hello all,
    I’ve been having trouble with Master templates. I’ll go to the sequence menu, Add Master Template, pick the one I want, but when I double-click to bring it into the viewer, there’s nothing there, it’s just black. Yet I know it’s there because the Controls tab has the text field field, allowing you to make changes, but there’s nothing to make changes TO. The same thing happens when I create a template for myself in Motion and bring it over to FCP…the thumbnail plays, but when I load it, the text itself does not appear.
    Any thoughts?
    Jerry Hofmann replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 18, 2009 at 2:09 pm
    Sounds to me like an install gone awry. Best fix is to wipe your hard drive after backing it up, and reinstall the OS, update it all the way, then install Studio, and update it all the way.
    You should do this on a regular basis if the machine is a busy one. At least every 9 months or so, and any time you upgrade your OS, or upgrade to a new version of Studio.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
