Activity Forums Apple Final Cut Pro Legacy Master DVCPRO HD (720p60) to AJ-1200a
  • Master DVCPRO HD (720p60) to AJ-1200a
    Posted by Yamil Ahuile on January 17, 2008 at 7:13 am
    I’ve finished a project and need to master to DVCPRO HD tape. I’m planning on renting the AJ-1200a and was wondering if anybody has done this procedure before. I plan on having a self-contained QT in the same format as footage/timeline (720p60). I don’t have a card and understand that it can be transferred via firewire. Also wanted to know if there are any drawbacks to going firewire. I have a G5, dual 2gig.
    Thanks in advance for your replies.
    -yamil
    Walter Biscardi replied 18 years, 7 months ago 2 Members · 1 Reply
  • Walter Biscardi
    January 17, 2008 at 12:10 pm
    You must control the 1200A via Firewire when you Edit to Tape. RS-422 is disabled for any editing functions.
    Thus, the deck will have an offset from 11-20 frames from your actual in-point. You will have to run multiple Edit to Tape tests if you require your master to start as a specific timecode, such as 01:00:00:00.
    You can ONLY perform an Assemble Edit with this deck, so there is no need to black a tape.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
