Activity › Forums › Adobe Premiere Pro › Mass delete audio tracks within audio clips
  • Mass delete audio tracks within audio clips
    Posted by Edward Harby on June 3, 2016 at 6:01 pm
    Sound guy goofed. Now I have 8 tracks of audio for each audio clip but only need two per clip. It’s pretty consistent by being only on the first two tracks, the rest are completely empty but still exist thus filling up my sequences with empty yet editable tracks.
    is there away for me to mass delete the useless tracks so editing can be a bit more use friendly for other audio elements like SFX and Music?
    Jon Doughtie replied 10 years, 3 months ago 3 Members · 3 Replies
  • Alex Udell
    June 3, 2016 at 6:17 pm
    In your project panel….select you clips…
    right click > Modify > Audio Channels
    change to what you need….
    won’t change what’s in a sequence….
    but will change future uses of the clip…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Edward Harby
    June 3, 2016 at 11:53 pm
    This worked. Thank you.
  • Jon Doughtie
    June 7, 2016 at 9:37 pm
    And if you find yourself working with a lot of material like that, you can save presets in that Modify/Audio tab for convenience.
    Most of my P2 footage has only channel 1 & 2 audio, so I have preset that knock out unneeded channels.
    I also have a preset simply called, “No audio, please!”
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
