Activity Forums Adobe After Effects Masks problems – Beginner
  • Masks problems – Beginner
    Posted by Astie001 on October 18, 2005 at 11:06 am
    I am trying to scale and move an image behind a mask. I can’t seem to keep the mask seperate from the image. Can anyone help? The mask scales when I try to animate scaling the image? How can I change only the image without changing the mask?
    Alistair
    Gabriel Alvarez replied 16 years ago 4 Members · 3 Replies
  • Criis Daw
    October 18, 2005 at 3:31 pm
    put the mask on another layer
  • Dole28
    October 20, 2005 at 2:04 pm
    Make a new solid the same size as the comp then make the mask on this layer instead. Click on the switches/modes button along the base of the timeline (I say this because it too me ages to find it when I had the same problem) then where it says trkmat change it from none to alpha matte ‘white solid, new solid, black solid, whatever the layer is called’.
  • Gabriel Alvarez
    September 18, 2010 at 5:33 pm
    Works like a charm
