Activity › Forums › Adobe After Effects › Masks change position when rendering
Posted by Jmriquel on May 23, 2006 at 12:53 pmHi guys i hope ya can gimmme a hand with this… im doing a some rotoscoping with a lot of masks, everything looks smooth and nice when i ram preview it, but when i render the file…(dv avi ) most of the masks have shifted position. i
Jmriquel replied 20 years, 4 months ago 4 Members · 4 Replies -
Mylenium
May 23, 2006 at 2:46 pmAre you sure you rotoscoped in a square pixel comp or at least used the aspect ratio correction for the comp preview window? I’ve fallen into this trap a few times myself, so it may be worth checking this.
Mylenium
[Pour Myl
Frank Ruggiero
May 23, 2006 at 2:57 pmi found that sometimes i have that problem as well when i render out the finished roto with fields. since you cant see each individual field in the timeline it looks ok on ram preview. but when you render with fields there is shifting, because your mask is not lining up (because you did not roto each field.)
usually we deinterlace the footage first and work with that footage. or ill take the original 29.97 clip and put it in a 59.94 comp and roto it in there (now i see every field.) then ill put that comp back into a 29.97 comp and render.
hope that can help you figure a solution.
-frank
Sam Moulton
May 23, 2006 at 3:57 pmthis is the same thing i’ve found. I always now roto at double the frame rate when working with interlaced video. all you have to do is open up the comp settings and type *2 after the listed frame rate, then when you’re done type /2. You must separate fields for this to work. I’ve never ran into the problem of the par causing trouble but then I never do any actual work with par preview turned on because i beleive the warning
Jmriquel
May 23, 2006 at 9:31 pmthanks guys, i tried doubling the frame rate of the comp to do the roto and now everything looks ok when i render…. ya save my day!
