Activity Forums Adobe After Effects Expressions Mask.maskFeather variable
  • Mask.maskFeather variable
    Posted by Nicolas Elsig on May 10, 2010 at 8:13 am
    Hello,
    is there a way to set the value of the mask feather in the following script … I tried a lot of different ways, but I’m just starting AE scripting and I’m totaly lost.
    Thank you for your help
    function convert3DToMask(){
    var currentComp = app.project.activeItem;
    var selectedLayers = currentComp.selectedLayers;
    var nbSelectedLayers = selectedLayers.length;
    var prefixS = "2Dmask_";
    var suffix = "";
    var newLayer;
    var currentLayer;
    var newName;
    var size = Number(solidSizeFld.text);
    if (app.project.activeItem.selectedLayers.length > 0)
    for (var i = 0; i < nbSelectedLayers; i++)
    currentLayer = selectedLayers[i];
    newName = prefixS + currentLayer.name + suffix;
    newLayer = currentComp.layers.addSolid([0,1.0,0], newName, size, size, 1);
    newLayer.name = newName;
    newMask = newLayer.Masks.addProperty("Mask");
    newMask.inverted = false;
    myMaskShape = newMask.property("maskShape");
    myShape = myMaskShape.value;
    myShape.vertices = [[size*0.25,size*0.25],[size*0.25,size*0.75],[size*0.75,size*0.75],[size*0.75,size*0.25]];
    myShape.closed = true;
    myMaskShape.setValue(myShape);
    expression = "L = thisComp.layer("" + currentLayer.name +"");L.toComp(L.anchorPoint);";
    newLayer.position.expression = expression;
    writeLn(currentLayer.name + " was converted to 2D mask");
    writeLn("with a size of : " + size);
    else
    alert("Select 3d null layers to convert", "Warning", true);
    Nicolas Elsig replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 10, 2010 at 3:00 pm
    I haven’t tested it, but something like this should work:
    newMask.property(“maskFeather”).setValue([10,10]);
    Dan
  • Nicolas Elsig
    May 10, 2010 at 3:53 pm
    thank you !!! SO MUCH !
    I was trying this way :
    // myMaskFeather = newMask.property(“maskFeather”);
    // myMaskFeather.setValue(15);
    but it was always making errors… so thanks a lot and here’s my script
    (coded with feet… but for a first script I’m happy) It’s a tool to transform 3D locators from maya and syntheyes in my case to a 2D_null, a 2D_solid with a mask or a 2D_patch… the 2D patch is used to replicate and offset a small portion of a footage to erase the tracked markers.. simple but so usefull for the project I’m working on…
    I know there are a lot of improvments to be more powerfull :
    mask size is in percent but if you set under 50% it will invert the mask, as it is based on the vertex position.
    feel free to use it and improve it… (and share your feeedback) I think I will try to go further with my poor scripting skills. I will try to give the user the ability to bake the expression on the created objects position. And a second feature would be to translate it in french 🙂
    the link to download is : https://www.mokastudio.tv/data/moka3dto2d_v3.0.jsx.zip
