Activity Forums Maxon Cinema 4D masking out part of a material for compositing
  • masking out part of a material for compositing
    Posted by Jake Martin on May 18, 2013 at 10:18 pm
    Hi
    I am rendering out a globe.
    So I have one big world texture on a sphere.
    I need to composite in a plague spreading across Africa.
    So I have a mask for the parts I need.
    My question is where do I put the mask in C4D so that I get a mask in the multipass.
    If I put in the alpha channel of my material it cuts out part of the map.
    I have been at this for days, can somebody please help.
    Jake
    Adam Trachtenberg replied 13 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    May 18, 2013 at 10:46 pm
    I would create the alpha and then do a separate render with just your globe and cameras to get the object buffer.
  • Jake Martin
    May 19, 2013 at 7:36 am
    Thanks Adam
    I tried that before but when I got it into After Effects the cameras seemed out of sync.
    I was using a regular camera and animating it. Is the sync thing a C4D or AE issue do you think?
    The animation was also a bit jerky so now I’m going to try camera morph.
    Cheers
    Jake
  • Adam Trachtenberg
    May 19, 2013 at 3:56 pm
    Hmm, there should be no difference assuming you didn’t change the Cinema camera settings … and have the same frame rates.
