Activity › Forums › VEGAS Pro › Masking on white background shows nasty black lines
  • Masking on white background shows nasty black lines
    Posted by Wojciech Hołysz on May 22, 2011 at 7:47 pm
    I have a video material shot on white background but with edges beeing a bit yellowish. So I decided to mask the person in the white center of the screen and put the track over a solid white background, but when I do that I gest nasty black lines along the Mask, and no Feather setting helps (it actually makes it look like a shadow).
    Can anyone help?
    Phil Peacock replied 15 years, 3 months ago 3 Members · 6 Replies
  • D. Eric franks
    May 22, 2011 at 9:30 pm
    Are there any effects at all applied to the clip/track that has the mask on it?
  • Wojciech Hołysz
    May 22, 2011 at 11:12 pm
    No, it`s a clean track. The feather option acts insane too, let`s say on 7,5 it`s an insanely big shadow along the masks line, and on 7,6 it`s a perfect fade…
  • D. Eric franks
    May 23, 2011 at 2:59 am
    I’ve seen what you are talking about before (I used to do what you are doing all the time), but not recently and I seem to remember some sort of effect causing it, but I can’t remember what (and it wasn’t an obvious one – just a bug). I know. Real helpful. Sorry!
    One other option might be to luma- (or chroma-) key the yellow out and use feather on that to blend. That’s actually what I used to do, with the mask only being for garbage at the edges.
  • Phil Peacock
    June 2, 2011 at 10:47 am
    Hi, just noticed your post. Don’t know if you have resolved it but are you aware of the ‘pre and post’ application of effects? There is a small arrow pointing left or right on the left hand side of any effects that you have applied on the clip. Try changing this.
    I did notice however that someone asked if it was a clean track which apparently it is. If so, sorry, not much help.
    Good luck.
  • Wojciech Hołysz
    June 2, 2011 at 12:04 pm
    Thanks fo your hints – I can`t see any arrows next to effects, where should I look for those?
    Here`s how i ‘bypassed’ (cause definately not solved) my problem. I Mask clips, Disable all Track/Clip effects – then I have a clean mask. I render this to a file and do Effects in another session.
    Apparently these lines/shadows ONLY appear when using any sort of effects on the clip/track that is beeing masked. That`s the most stupid bug i can think of, I don`t know how they could let it happen.
  • Phil Peacock
    June 3, 2011 at 7:53 am
    Hi again.
    Have a look at this post below. Same problem as yours and the same issue I had. It is difficult to explain it but it is to do with adding effects to the masked/masking clip pre and post masking.
    But here is the arrow, (in the video fx window); give it a try. It was a very simple solution for my shadow problem!
    https://forums.creativecow.net/thread/208/877636
