Activity Forums Adobe After Effects masking on already 3D text on round path
  • masking on already 3D text on round path
    Posted by Dawud Ali on April 2, 2011 at 1:40 am
    THANKS FOR YOUR TIME
    IS CASE U ARE CURIOUS ABOUT THE CAPS I WAS RENDERING WITH CAPS ON
    TO PREVENT PREVIEW 🙂 MOVING ON!
    HI GUYS DOES ANYBODY KNOW HOW MAKE AN EDITED ( ONTO A PATH) AND
    3D TEXT LAYER MASK EASILY. OR AT LEAST MAKE IT APPEAR 2D JUST FOR
    THE SAKE OF MASKING SPECIFIC TEXT .
    FOR EXAMPLE WHEN A TEXT LAYER IS 2D OR FLAT IT’S EASY TO APPLY AND
    ANIMATE A MASK BUT THE PROBLEM I HAVE IS A ‘3D’ THE TEXT WHICH IS ON A
    CIRCULAR PATH WITH THE CHARACTERS STANDING 90 DEGREASE UPRIGHT
    ON THAT PATH LINE, WITH THE TEXT LAYER ALSO AT 90 (IN PERSPECTIVE)
    NOW I NEED TO MASK PARTS OF THE TEXT MOMENTARILY
    AND THEN REVEL IT WHEN I NEED TO.
    THE TEXT IS ON A CIRCULAR PATH WHEN WHEN I ANIMATE THE FIRST MARGIN TO MAKE IT MOVE ALONG THE PATH SOME OF THE TEXT WILL OVERLAP THE PART BEHIND IT, MEANING I WANT TO HIDE THE PART WHICH OVERLAPS.
    Dawud Ali replied 15 years, 5 months ago 2 Members · 2 Replies
  • Joey Foreman
    April 2, 2011 at 2:03 am
    Couldn’t you precompose it, and apply and animate the mask in the precomp? Or, use the Range Selector with an Opacity Animator in the main comp?
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Dawud Ali
    April 3, 2011 at 8:31 pm
    hi, my man
    the animator for opacity range selector worked like a beast, just a bit more refining would give me the exact result I’m looking for. i’ve been using after affect for while but it’s taken me long to notice the text animator options -_-
    moreover i already precomposed the text animation but i had problems with unwanted text overlapping the text i wanted, so normal masking wouldn’t work but tnks for sharing the knowledge
