Activity › Forums › Apple Final Cut Pro Legacy › Masking / Ltrbxing a ripple dissolve effect?
  • Masking / Ltrbxing a ripple dissolve effect?
    Posted by Lisa Rolley on March 11, 2009 at 5:20 pm
    Hello
    I am working in a DVNTSC timeline with animations which are 720×405 so the ltrbxing is automatically happening – I’ve been asked to add a cheesy ripple dissolve effect between 2 clips and the problem is that the ripple itself goes outside the ltrbxing.
    I want to know the easiest / best way to crop the rippling which is going over the ptrbx line of the animations.
    Thank you in advance for your help
    Best
    Lisa
    Lisa Rolley replied 17 years, 6 months ago 1 Member · 1 Reply
  • Lisa Rolley
    March 11, 2009 at 5:25 pm
    UPDATE:
    Tell me if this is the way you gusy would have done it:
    I just grabbed a solid shape and had it match the black and just copied another one on top of that – both cropping the bottom and top line where ltrbx is in order to cover the over-flowing ripple cheesy effect : ))
    How else could i have doen this?
    Thank you!
    Lisa
