Activity › Forums › VEGAS Pro › Masking in Sony Vegas Pro
  • Masking in Sony Vegas Pro
    Posted by Kaan Yilmaz on January 7, 2012 at 11:40 am
    Hello,
    What I basically want to do, is replace a character of a movie, with my character. So the first thing that came in my mind was masking my character, so the background wouldn’t be seen, and negatively mask the character in the movie. Now, this did work, but my scene is 3 mins long, and it has 24 frames a second. That would take a whole lot of time to make, since I would have to mask every frame. Is there any quicker way to do this?
    Thanks in advance,
    Kaan
    John Rofrano replied 14 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    January 7, 2012 at 3:34 pm
    [Kaan Yilmaz] “Now, this did work, but my scene is 3 mins long, and it has 24 frames a second. That would take a whole lot of time to make, since I would have to mask every frame. Is there any quicker way to do this?”
    You would need a tool like the Roto Brush in After Effects. There is no way to automate this in Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kaan Yilmaz
    January 7, 2012 at 4:36 pm
    Thank you John,
    Do you have a link of a tutorial on how to do that? I did find some tutorials, but they are not quite showing what I want to do.
    Kaan Yilmaz
  • John Rofrano
    January 7, 2012 at 4:47 pm
    [Kaan Yilmaz] “Do you have a link of a tutorial on how to do that? I did find some tutorials, but they are not quite showing what I want to do.”
    There are Roto Brush tutorials on the Adobe TV web site:
    Rotoscope with RotoBrush in After Effects CS5
    ~jr
  • Kaan Yilmaz
    January 8, 2012 at 3:54 am
    Thanks for all your help John, I got it working, although I have a small problem. When I render it, and open it in Vegas, it still shows a background, but this time black. How should I make that whole background disappear? I read somewhere that the Output Module should be “Lossless with alpha”, but that didn’t work.
    Thanks in advance,
    Kaan
  • John Rofrano
    January 8, 2012 at 5:42 pm
    [Kaan Yilmaz] ” I read somewhere that the Output Module should be “Lossless with alpha”, but that didn’t work.”
    That’s exactly what you need to do. The alpha channel carries the transparency. That doesn’t mean that Vegas will see it without some help. If you rendered lossless with alpha, right-click on that event in Vegas, open the Properties and on the Media tab set the Alpha Channel to Straight (Unmatted). That should make it work.
    ~jr
  • Kaan Yilmaz
    January 8, 2012 at 5:53 pm
    Woah, thanks John, it worked!
    Kaan
  • John Rofrano
    January 8, 2012 at 9:11 pm
