Activity › Forums › Adobe After Effects › Masking footage with keyed alpha channel
  • John Cuevas
    December 20, 2011 at 6:33 pm
    Apply your effects first. Now choose your layer and under “Layer” choose precompose “shift+cntl+c”(PC), now you can apply your mask.
    Another method would be to create a layer(solid) over your effected layer, add a mask to that layer and change your effected layers Track Matte to alpha.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darby Edelen
    December 21, 2011 at 11:25 am
    The “Set Matte” effect should work for you.
    Darby Edelen
