Activity Forums Apple Final Cut Pro Legacy Masking a Person From Background
  • Masking a Person From Background
    Posted by John Leblanc on September 5, 2009 at 2:37 am
    I’m trying to mask/isolate a person from the background and put a moving shot background behind him. No green screen. Slight camera movement but very slight. I cannot use a difference matte because I don’t have a frame of the shot without the person in the shot.
    I have no experience with masks or mattes.
    I’d settle for simply finding a way to cut out this person, feathering the edges a bit, so the matte would not have to be exact on every curve.
    But, it would seem to a novice like me that if you can create a near mask or an inverted matte in the color corrector filter using the limit functions (by using saturation, luminance, etc.) to isolate parts of your subject) to color correct, then you should be able to do something similar with luminance, etc. to create a mask of your subject and isolate him from his surrounding.
    How do I do this? And if I can’t do this, what tool can I use to cut out the person and then feather the edges slightly? If you can point me to a tutorial, that would be great, because I need instruction.
    Thanks.
    John Leblanc replied 17 years ago 2 Members · 2 Replies
