Activity Forums Adobe After Effects Masking a Pattern without having the base shape cutted
  • Masking a Pattern without having the base shape cutted
    Posted by Marten Zander on April 9, 2016 at 10:23 pm
    Hey,
    I would like to know it there is a way to mask a pattern without having to cut the edges. Let’s say I have a hexagonal pattern grid on a shape layer created with a single hexagon and the repeater function. Now I want to make these Hexagons to display a specific logo type. Can I somehow make the pattern use a luma matte to be displayed or being hidden? By that I don’t mean the normal luma matte, because that would cause some of my hexagons to be cutted at the edge. I want to have a single instance to have two options, being displayed or not.
    I already know about the “sampleImage” expression, but since I want the grid to be very tiny I would have too many instances and this would cause my Computer to crash
    What I like about the “sampleImage” Expression is that I have perfect control about whats displayed and how I can use it to also make a revealing animation.
    Is there any workaround? Or does anyone know How I could improve my computers performance to work with very tiny patterns with a lot of instances ?
    Thanks in Advance!
    Marten Zander replied 10 years, 5 months ago 2 Members · 4 Replies
  • Kalleheikki Kannisto
    April 10, 2016 at 8:43 am
    I would use Trapcode Form. Hexagonal pattern is a bit challenging, as you need every other row to be shifted, so you need two layers with Form and two slightly offset copies of the layer map that controls the transparency. But you can definitely do it there, plus you will have 3D particles to play with.
  • Marten Zander
    April 10, 2016 at 1:32 pm
    This is brilliant, easy and very performant. Thank you for the hint…! 🙂
    April 10, 2016 at 6:24 pm
    PS. You’ll need to curve the alpha channel so that there are no semitransparent particles at the edges.
  • Marten Zander
    April 11, 2016 at 7:29 am
    Yes I already noticed… , but anyway its a good workflow!:)
    Screen Designer/ Front-End Developer at Slim Interactive GmbH
    http//www.weareslim.de
