Activity Forums Adobe After Effects masking a light layer and grading lights
  • masking a light layer and grading lights
    Posted by Anita Sancha on August 8, 2009 at 5:13 pm
    Hi..
    I have messed up a bit with a light layer and now can not put the light between 2 layers in 3D space where I want it, as I have just done tooo much work to the project, this might effect other layers in a many hundred layer project. But where the light appears from the cameras view, it would be fine if i could mask and feather it a bit, but I cant as it appears lights cant be masked…. or can they?
    Also how can i make the lights graded so they are more intense nearer the bulb?
    Thanks.
    Thanks for all your help
    Anita Sancha.
    http://www.anitasancha.co.uk
    Beatrix Snyman replied 16 years, 4 months ago 3 Members · 2 Replies
  • Todd Kopriva
    August 8, 2009 at 6:21 pm
    Regarding making lights less intense with greater distance from the source: This is usually called ‘light falloff’. Here is a Community Help search for ‘light falloff’ that pulls up a few pages with workarounds for simulating light falloff.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Beatrix Snyman
    May 5, 2010 at 9:44 am
    Hi there,
    I’m still having problems with masking lights even after reading through these posts. Maybe I’m not understanding it clearly. Here is my scene:
    I have a camera that is showing the inside of a hut, which I constructed in Photoshop. On the left is a doorway which is open. I’ve placed a spot light on the left to simulate a sun beam. But the beam is also falling on the doorway’s inside (which is incorrect). I’d like to mask the part of the spot light which is falling on the doorway. I’ve tried to make a shape layer and make a mask on that shape layer, copied that path of the mask and pasting it on the spotlights position layer. But that only takes out my whole light. I’ve even change my mask to “inverted”.
    Help would be appreciated.
    Beatrix
