Activity Forums Adobe After Effects masking
  • Posted by Dan Mountford on June 20, 2011 at 2:45 pm
    Hey
    can somebody tell me how he achieved the effect where it is sort of cut and the offset slightly in this video where its used throughout?
    https://vimeo.com/25347237
    Thanks so much!
    Dan Mountford
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Bill Williams replied 15 years, 3 months ago 3 Members · 4 Replies
  • Bill Williams
    June 20, 2011 at 2:52 pm
    I would throw an adjustment layer on top of your layers and draw your desired mask. Apply the transform effect (effect/distort/transform) to the adjustment layer and change the anchor point, or scale…
    Hope it helps!
    vurb.tv
  • Tudor “ted” jelescu
    June 20, 2011 at 2:54 pm
    It may be a directional hard edge wipe, between two layers with the same footage, where one layer is offset a few pixels and has motion tile applied to it.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Dan Mountford
    June 20, 2011 at 2:58 pm
    cool, thanks guys!
    And what about the growing typography is that masking too?
    does it have a specific name so I can search up a tut and not annoy you guys?
  • Bill Williams
    June 20, 2011 at 3:00 pm
    I would just animate the stroke effect on your type, but make sure to set it to “reveal original.”
    vurb.tv
